Opinions on Best 12" 1000rms subwoofer for SQ>SPL ~$300 range
zoltman1991
CarAudio.com Regular
I have two 12's. I'm not too impressed. I don't know. It's loud, but I felt my single 15" was louder, however didn't sound as clean as I'd like.
Thinking of switching to a single 12" at 1000rms instead of two 12s at 500rms.
First off, what is everyone's thoughts? I listen to primarily electronic. Currently in 4.5cuft at 33hz. Should I shoot for a higher tuner? It sounds good, but I feel I'm lacking some loudness to it. I want a good balance of SQ and SPL, with a focus on the SQ.
Looking at:
Sundown SA-Series v.2
Skar Audio DDX-12
Resilient Sounds Gold 12 (I've heard good things in regard to SQ)
So many options. I'm also seeing Incriminator and Ground Zero.
Thanks!
Dual Kicker Comps. Box is fine. I did a lot of research. Matched the recommended enclosure. 4.5 cubic feet at 33hz. Unless you know otherwise and suggest something else.
Got it. I have not reallly heard those Kickers but some I have heard and really liked are the Alpine TypeR. A good blend of SQ and low end power. Smaller box than the Kickers as well.
Stereo Integrity SQL always gets good reviews from the forums.
Takes a lot of power and uses smaller boxes.
Plus one.
Works in as small of a box as .7 cubic feet sealed.
Also had mine in a 1.75 cubic foot box ported to 36. ****** slammed. Only thing was it didn't hit lows like at all but only cause the box was tuned so high. Had it on a JP8 amp but I never had full voltage and dont have a high output alternator so it could've been muuuch louder.
If you're going sealed Nick (owner of SI) recommends.7-1.0 cubic feet, most people to prefer the box size to be on the smaller side from what I've seen, mine sounded pretty good on 1.0 cubic feet in a sealed box. If ported, go 1.8 cubes tuned to 30hz. This sub has about 2 inches of linear throw so you'll need a decent amount of port area as well.
I don't have mine anymore, I actually upgraded to their 18 inch HT-18 and I'm really liking it. Only $200 and 2 inches of linear travel. Plan on getting a second one after I'm able to upgrade my electrical system more
zoltman1991
zoltman1991
houston
fa5chups
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
