opinions on 15's
big boom crew
I bought a 01 chevy 1500 single cab not to long ago and am planning what I want to put in it. im thinking 2 15's around 1500 rms each any opinions on what I should get im liking the fu audio 1750 I think is what there called. also any opinions on the fu audio subs?? thanks in advance
Trust me, will not fit 15's.
Good luck if you're not doing a blow through
why wont it fit 15's fit after sliding the seats up I have 11 1/2 in of depth for the 15s and everything will be mounted in the tool box in the bed so why wont it fit?
im 5'9 have a 1990 sinclecab and 2 15s will NOT fit in a chevy. atleast not in proper boxes. crappy tiny sealed boxes yes. adequate boxes HELL NO. single 12 or 2 8s is all we have space for
i actually have a box just siting in my garage for these trucks. takes up entire rear wall and max top and bottom depths. MAX before subs and port is around 2.8 cubes. atleast with a comfortable driving position pushed up uncomfortable and unsafe against the wheel you might get 4 cubes out of it MAX
single 12 no I had 2 sa 12's in my single cab s10 in a proper sized box it was tight but it worked and the 1500 was a lot more room then my s10 had im positive I can get 2 15s to fit. I feel like I might have to get some pictures so you can understand I have room
a 15" needs from 4-5^ft per sub ( depending on sub ). after displacement.the box would have to be bigger then you think.
maybe if you walled it.
I don't think I can wall it I just don't think it will work right and I know the box will be bigger then you think but I also can slide the pass seat all the way up as I don't normally have people ride with me
I am also going to take the console out and make one I have 2 bucket seats with a console in the middle so I can move it to where I would like or maybe make the box apart of the console
Giving subs more power really wakes them up. The MRP-500 is pretty low power. You would really notice more authority in your bass.
661
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
JL RD1500.1 does rated power @1 or 2 ohms, Does 1800 to 1900 watts in tests I've seen.. Designed buy a guy who designed old school PPI and Xtant...
13
big boom crew
big boom crew
valdosta,GA
oxsign
    Apr 27, 2024
audiobaun
    Apr 27, 2024
