only sub plays when I use the aux
Spike243
I just installed a Sony GT250Mp head unit that powers all 4 car speakers. I also have 1 12" JL sub that is powered by a mono amp. Whenever I try to use the aux port on the deck only the sub plays?
Everything works fine when I use the radio. Any help is appreciated
Edit: This also happens when I play cds
Check the hu manual for settings. This is what I see in the manual you may need to look at.
Changing the sound settings:
Press the select button repeatedly
until “BAL,” “FAD” or “SUB” appears.
The item changes as follows:
LOW*
1 t MID*
1 t HI*
1 t
BAL (left-right) t FAD (front-rear) t
SUB (subwoofer volume)*
2 t AUX*
*1 When EQ3 is activated (page 10).
*2 When the audio output is set to “SUB-OUT”
(page 10).
“ATT” is displayed at the lowest setting, and can
be adjusted up to 21 steps.
*3 When AUX source is activated (page 11).Press the select button repeatedly
LOW*
1 t MID*
1 t HI*
1 t
2 t AUX*
(page 10).
REAR/SUB*1
Switches the audio output: “REAR-OUT”
(power amplifier), “SUB-OUT” (subwoofer).
LOW*
1 t MID*
1 t HI*
1 t
2 t AUX*
(page 10).
LOW*
1 t MID*
1 t HI*
1 t
2 t AUX*
(page 10).
REAR/SUB*1
So what settings should I change?
Spike243
Spike243
Montana
Spike243
