One sub louder than the other?
kdrose23
Hey guys. I just installed my new system and I have a slight problem. My right sub is slightly louder than my left. When I look at the subs playing I can clearly see a difference in the vibrations. I have the two subs connected to a 4 channel amp bridged to run just the subs. I already checked the gain on each channel and they are the same. all connections are correct, I checked them many times. I cant seem to figure out why one sub hits harder than the other. I also only have one set of RCA connections on my head unit, so I have one RCA cable connected to the head unit and on the end connected to the amp, I have it split with two Y splitters (so there are 4 total male ends to plug into the 2 sets of RCAs on the amp) Perhaps these RCAs are the problem? since there is only one set on the head unit which one i front and rear? Any help would be appreciated
check your sub wiring to make sure they have good solid connections.
I had a similar issue one time with a speaker wire barely hanging on the sub box terminal. It caused that sub to have less power/excursion that was very visible.
you said all connections are correct, what about inside the sub box?
Ok so I checked all my wiring and it's all good. But one thing I did notice. When I flipped flopped the subs (put the one from channels 1&2 onto channels 3&4 and vice versa) the opposite sub became the weaker one. So it's not the subs. Channels 1&2 seem to be slightly weaker than 3&4???? Any thoughts on this?
kdrose23
kdrose23
New York
globalminds_ent
michigan born
    May 14, 2026
michigan born
    May 14, 2026
