rizorith
OK so I have my stealth box and my 10" speaker. But I'm at a loss of what I should do now. I have 8 1 1/4" drywall screws and I was told to pre-drill the holes first.
1. Does that mean I use a drill and drill the holes and then hand screw the screws in? What size bit should I be using to drill the holes?
2. How do I connect the speaker to the speaker wire? I've never seen a connection like the one it has. It's something I sort of unscrew and then there is a hole in the middle of the bolt that is exposed. Do I just wraps the wire around it and screw it back up?
3. Is it OK if the fil that is in the box touches the speaker? If not I'll have to take a lot out and it won't meet the requirements I've read about.
