New Rockford Fosgate T1's are BEAST!
I have a 12'' sub I'd throw against your T1. Half the cost as well. Your Rockford has been going downhill for years. Their garbage they make now is nothing compared to their great classic equipment. Get your uneducated, nut-hugging arse the fuck out of here!
Lolz. For that price I could get a Sundown Nightshade, Z, DD 3500 or 9500 series, FI BL, BTL N2, AA Havoc, DC Level 4 or XL, Cadence ZRS, or even an HDC3 or HDC4 to name a few. Oh well, guess I'll stick to my non mainstream junk //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I don't care how off topic this is, that avatar you have of a cat-a-chu is ******* awesome.
I work at a car audio shop. the 2010/2011 Power T1 subs are insane. 12" 800RMS. In a big slot ported box with more than enough power they are crazy loud.
Power rating is very, very conservative. On 1000RMS it barely tickles it, even after extended periods. The voice coil cooling is absolutely superb, which attributes to the high thermal power handling. The whole cone is a heatsink, not to mention the other finned heatsink on the front side of the magnet, as well as being well ventiliated.
Other guy I work with ordered two of the 12s, and one ended up being defective, just making a little noise in the voice coil. In order to get the serial number to RMA it, you have to cut the cone out of the sub, in other words destroy it.
So before we did that, we decided to WALL SOCKET IT, yess always fun. Well, try to anyways. Plugged it in 120v AC, and off she went, crazy excursion. It was going nuts for 5 minutes straight, and wouldn't stop. But we had to stop, so we gave up. The worst it did was a little bit of smoke.
Moral: the new Rockford Fosgate Power subs are bulletproof.
Anybody else have the joy of having one?
I will be sure to tell this to the guy at work with 2 of them on a 1501db....the same set up that my 1 3512 PWND......
This thread has got way out of hand. Poor guy. I know I was there before but I shut up and did some learning.
I learnt we all have cheap junk.
I learned that if u blow an Fi sub it is ALWAYS your fault! And u will be flamed as necessary. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
r0llinlacs
r0llinlacs
Iowa
av83
    May 16, 2024
    May 16, 2024
