New Build Beginning
bgowdy
Heroes are remembered, but legends never die
So im about to start my build in my new truck(if you want to call it that). Im not really doing a huge build log for it, but i will throw up some pictures once its gets going. Building for daily that is able to put up decent numbers on TL.
The Vehicle will be a 01 Hyundai Santa Fe:
Equipment:
Sub(s) - 2 Soundqubed Sdc2.5 15's
Amp(s) - 1 Shark 2500d for now (will be 2 strapped when its fully done, and set via dmm/scope for 2500rms from the pair)
Wire(s) - 4 Runs of 1/0 front to back batts(2 positive and 2 dedicated negative runs)
Battery(s) - 1 Deka under hood - 2 Agms in back
Big 3 - Will be 1/0 when i figure out how to get to the alt(its under the engine //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif )
Alt - Stock for now
Enclosure - 8.24 Cubes Gross - 7.06 cubes net(3.53 cubes per sub) - 1-10" Aero(78.5 sq-inches of port) - 11.1560 sq-inches port per cubes - Tuned to 37hz
thoughts?
I still prefer a bigger enclosure...I always run way over RMS but usually with HDC3's & 4's. SDC's I usually do a pair on an AQ1200 or 2200, have built a lot of those set ups. 8-9cubes net for a pair of 15's...
i see, i just dont have that much room to give i like to leave some room to where i could pack a stroller or something with me lol. Once i get my other amp im going to set them around 2500watts before rise/voltage so it would even itself out
bgowdy
bgowdy
Campbellsville, Ky
bgowdy
