Need wiring help, over my head
  • 5
eaby152
I have put system after system in cars all very basic... For Christmas I got 2 dvc mbquart 4 ohm subs and I want to run it on a 2 ohm stable md sound 1200 watt max amp (2channel). Have no idea as far as my options for wiring can anyone help
you can't.
your welcome.
Even if I take one sub wire it parallel make it 2 ohms and do the same with the other and don't bridge the subs together? I seriously don't know.
I guess I just need to know if my amp can run 4 ohm bridged, it says it can be bridged and says on it is stable at 2 ohms. The amp is a mdsound md-2692lt 1200 watt max 2 channel
---------- Post added at 10:40 PM ---------- Previous post was at 10:40 PM ----------
What's the diff between stereo and mono what's better
Option 2 still has both subs on one channel
When you bridge you are combing the two channels also running the channels at 2 ohms you are getting the same power as bridged. Just in 2 separate channels So if your 500 watts bridged and or 250 watts x2 at 2 ohms stereo
I was thinking he meant the amp was 2 ohm stable bridged. Makes sense that its 2 ohm stereo, 4 ohms bridged. My bad
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
551
eaby152
eaby152
lititz,pa
eaby152
