Need wiring help, over my head
you can't.
your welcome.
I guess I just need to know if my amp can run 4 ohm bridged, it says it can be bridged and says on it is stable at 2 ohms. The amp is a mdsound md-2692lt 1200 watt max 2 channel
---------- Post added at 10:40 PM ---------- Previous post was at 10:40 PM ----------
What's the diff between stereo and mono what's better
Option 2 still has both subs on one channel
When you bridge you are combing the two channels also running the channels at 2 ohms you are getting the same power as bridged. Just in 2 separate channels So if your 500 watts bridged and or 250 watts x2 at 2 ohms stereo
I was thinking he meant the amp was 2 ohm stable bridged. Makes sense that its 2 ohm stereo, 4 ohms bridged. My bad
eaby152
eaby152
lititz,pa
eaby152
