Help installing system in 2014 silverado
Ericruiz911
Hey everyone,
I need some help installing my system. I WILL be keeping factory HU. System in NON-BOSE. Questions follow parts list.
Here is what i have:
MIDS/HIGHS
- Pioneer TS-D1720C for Front
- Pioneer TS-D1602R for Rear
- Precision Power PPI 900.4 (4 Channel Amp)
- LCQ-1
-14g speaker wire
SUBWOOFER
- SAZ-1200D
- (2) ID 10 v3's
- enclosure
1. Do i splice into the appropriate cables behind HU (Pre Amp) to get Signals and then run them to LCQ-1?
2. If so, am I just leaving the factory amp in place and just bypassing it?
3. Since i am running new speaker wire, what do I do with the OEM speaker wires/clips at the door? Do i leave them hanging there?
That's what I need answered to proceed. Thank you in advance!
NON-BOSE and you still have a factory amp? but for the other questions..
1. i spliced behind the stock radio.
2. you use the wires coming from amp if you have one.
3. use the same wires i don't think you'll be able to run new speaker wire to the doors.
thanks for the reply. I will pushing around 110 watts per speakers and i dont believe those OEM wires can hold that very well.
The runs will be short. But if maybe your truck isnt as difficult as my car. Give it a shot but if all else fails use them youll be fine. I have no trouble and thats what another guy did in his car running the ppi your going to run active.
I just did a 2014 silverado I used an lc6i tap wires either in the kick panels or behind the deck. This should give you 4 channels. You'll need to run wires from the integration unit to the speaker wires from the deck No amp to btw .
Ericruiz911
Ericruiz911
Miami, FL
mylows10
