Need Watts explained alittle
jace314
CT
Hey all!! Pretty much a newbie quest...
With a mono amp rated at 1600 watts @ 1ohm, and connecting 2 subs 4 ohm DVC using the wiring guide from here, exactly how do the watts get dispursed? Are the subs getting the full 1600, or are they getting 800 /sub? Was never sure how the monos worked?
Thanks
Hey all!! Pretty much a newbie quest...With a mono amp rated at 1600 watts @ 1ohm, and connecting 2 subs 4 ohm DVC using the wiring guide from here, exactly how do the watts get dispursed? Are the subs getting the full 1600, or are they getting 800 /sub? Was never sure how the monos worked?
Thanks
yes
Thanks much man! So I got 2 10"type r's, and im thinking of getting a hifonics mono 1600. So will the type r's be ok with 800 watts per? Is it sufficient, or over kill?
Thanks
running a parallel series, wouldnt he be getting a 2ohm impedence. 400 to each sub?
If they were dual 2ohm, then yes. He is running dual 4 ohm, so running all in parallel for 1 ohm.
if they were single 4ohm coils ya
but there dual voice coil 4 ohm
Parallel series means two DVC //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Edit: Fixed.
you can wire in parrellel with two single 4 ohm drivers //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I know, but he said parallel series //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
i gotcha now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif good eye //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So I should run them like the following diagram, yes? DVC's!
jace314
jace314
CT
jace314
