Need help designing a Pre Amp
Elliot Woodman
CarAudio.com Newbie
Hi, I am currently trying to upgrade the stock sound in my 1999 Volvo v70. However since I like the look of the factory Head unit, and would rather keep things looking stock as much as possible, I have decided to design and build my own car pre amp which will be nice and small so it can be mounted behind the original unit, and be sent to an external amp in the boot.
I am sure that it would be be much more efficient to just buy parts, but having a fair amount of electrical design experience, I am going to enjoy designing a circuit myself, even though I am well aware that it wont be anywhere near as good as off the shelf parts.
However I am not really sure what voltage my pre amp needs to output to pair well with a power amplifier, do I want as much voltage output as possible using the 14v available, giving me an output swing of around 12v peak to peak, or will the power amplifier also have some gain?
I have started designing a switching circuit that will allow for the pre amp to be triggered via the ACC feed from the ignition, and have done a sort of passive input stage, High Z, and with a high pass and low pass filter. however am not sure where to proceed, I will want some eq control even if its just treble and bass. and was planning on using NE5532 op amps for this and the voltage gain. hoping that they will be enough to provide an input to the power amp? possibly having a small class AB output stage if The op amps are being pushed too hard? does this sound suitable? I have attached my current progress.
I know this could be sorted in a couple hours if i just buy one, but again I am enjoying the process.
  • Schematic.pdf
Elliot,
It's great to see your enthusiasm for designing your own car preamp! Keeping the factory head unit while upgrading the sound is an excellent way to maintain the original look of your Volvo V70.
Regarding your questions about the preamp output voltage and amplifier compatibility:
1. Output Voltage: Ideally, you'll want your preamp to output a signal voltage that matches what most amplifiers expect as a line-level input. Typically, this is around 1V RMS, but your gain structure will depend on the amplifier you're pairing with. Many car amplifiers will expect input signals anywhere from 0.5V to 1.5V RMS to function optimally. Regarding your mention of a 12V peak-to-peak output, remember that this will translate roughly to around 5V RMS, which might be a bit too high for most amplifiers unless you are planning to include a way to attenuate the signal at the input.
2. Amplifier Gain: Yes, most power amplifiers have some gain, which means they can amplify a low-level input signal to drive the speakers adequately. It's usually good practice to aim for a preamp output that is compatible with the input of your amplifier without overloading it. Check the specifications of the amplifier you plan to use to ensure the output from your preamp will not clip at high volumes.
3. Design Considerations:
- The design of your switching circuit to be triggered by the ACC feed is a smart move, ensuring that your preamp powers on and off with the vehicle.
- Your approach to having a passive input stage with high-impedance (high Z) input and implementing high-pass and low-pass filters will help to eliminate unwanted noise and provide good sound quality.
- The NE5532 op-amps are a solid choice for audio applications due to their low noise and good slew rate. They should suffice for your intended purpose of providing a line-level output to the amplifier.
- If you’re considering a small Class AB output stage, it adds complexity but can be beneficial if you notice that your op-amps are struggling under load or if you want to drive the speakers without needing a separate power amp in some scenarios.
4. EQ Control: For equalization, you can implement simple tone control circuits based on active filters using op-amps. Just remember that with EQ controls, the design will add complexity.
5. Testing Assembly: Once you have your circuit laid out, make sure to build it on a breadboard first to test different components and configurations. This allows you to try various EQ setups and filter designs without committing to a PCB layout right away.
Overall, your approach sounds promising, and it's great to see your passion shine through in the design process. Don’t hesitate to iterate your design, and make adjustments based on testing.
Feel free to share your progress or any schematics if you’d like more specific feedback. I encourage other members to chime in with their thoughts or suggestions too!
Are you looking to build a Line Output Converter (LOC) to send speaker level signals to an amp? If so, I highly recommend a commercial unit. They're cheap and some are quite small. But if you insist, I have a few comments on your design so far.
First, HU outputs are differential, not ground referenced as your input circuit shows. You need differential amplifiers and you need to handle the DC bias that they have to ground. Each speaker lead has ~6 VDC to ground. Also, those op-amps want a split power supply. I've used a charge pump type converter in the past that gives you the -12 volt rail from a +12 volt input.
As for output voltage, anywhere from 2 to 4 vrms is fine.
I suggest checking into https://www.diyaudio.com/community/forums for expert advice. Good luck.
ok, thank you, I was aware that the amp would be expecting an offset, I was using a rail splitter in that schematic that provided a rail at half supply, that I have tied the signal to. This allows the 6v rail to be referenced as ground by the op Amps, so the real ground (0v) acts as the negative rail. I admit that the labelling on my drawings may be a bit confusing as I have called the 6v rail 0v, just so it all makes sense to me whilst figuring things out. depending on how well the Op amps can swing close to their rails, I expect that it should be running on 14v which is the otuput of the alternator. (at least wen rad fans, lights etc are not on) so for a +- 7v supply for the op ams. Assuming they can swing to around 1v of supply, a 6v peak signal corresponds to around 4.2 rms.
Also by differential, do you mean balanced? i could produce a balanced output with a simple inverting circuit for each channel?
cheers for the help :)
Woah, not sure why all the trouble to do this on your own; there are plenty of line-out converters that will do the job, and much more effectively.
You're starting with an OEM head unit, cassette/CD/AM/FM with Dolby- not bad, but not a great signal source to begin with - which means it's as good as it will get downstream (weakest link).
This will do everything you're looking for and then some.
I actually like the idea of building the preamp yourself, especially since you're doing it for the learning process rather than just trying to save money.
You don't necessarily want to push the preamp output as high as possible just because you have 14 V available. The power amp's input sensitivity/gain determines how much signal it needs to reach full output, so I'd design around the input voltage range of the particular amplifier you're planning to use.
An NE5532 can be a perfectly reasonable choice for the preamp/EQ stages. I'd pay particular attention to the supply voltage, output swing, input/output headroom, and how you're biasing the op amp if you're running it from a single 12–14 V automotive supply. You don't want to design around the assumption that a 14 V supply automatically gives you a clean 12 Vpp output swing.
I'd also keep the preamp output impedance reasonably low so it can drive the amplifier's input without problems. A buffer/output stage may be useful, but I'd first see what the NE5532 can comfortably drive before adding a Class AB stage.
For the gain structure, I'd probably work backwards from the amplifier: determine its input sensitivity, decide on the maximum clean signal you want from the preamp, then set the preamp's maximum gain/output accordingly. That gives you much more predictable headroom than simply trying to get the biggest voltage possible.
For a DIY project, I'd definitely keep the first version modular: input/buffer → EQ/filter → gain/buffer → output. That'll make troubleshooting and changing the design a lot easier.
Elliot Woodman
CarAudio.com Newbie
Elliot Woodman
England
Bumpbump
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
