need help on subs
vasvin99
ok im getting another sytem right now i have 3 audiobahnd 1200x subs they are loud but not loud enough. i want real real loud. i want those jl 12w7's but i heard they are not as loud as those kicker L7's or anything my price range is about 750 a sub or about 1500 i just want a real loud system. and i was looking at more audiobahns and it says the db efficiency is like 98.6 db i want about 150 -160 does that 98.6 have anything to do with it?? or is that a whole different topic? thanks vince
That's a whole different deal. It coincides with, but doesn't dictate SPL. Audiobahn subs are typically pretty loud. Before purchasing new subs you might want to reevaluate your install and the size of your amp.
If you did change subs I would recommend the Adire Audio Brahma. But since your purely into SPL, try posting something specifically to RANGERMAN. He's an SPL freak like yourself.
efficiency is how the subs are tested for...well efficiency. They test them by putting 1 watt into the speaker at 1 meter away. Higher efficiency better, but you will be lucky to find higher than 100, if that, maybe 95... but like stated above doesn't mean you will be louder if it has higher sensitivity...install, brotha, install....
Originally posted by vasvin99 ok im getting another sytem right now i have 3 audiobahnd 1200x subs they are loud but not loud enough. i want real real loud. i want those jl 12w7's but i heard they are not as loud as those kicker L7's or anything my price range is about 750 a sub or about 1500 i just want a real loud system. and i was looking at more audiobahns and it says the db efficiency is like 98.6 db i want about 150 -160 does that 98.6 have anything to do with it?? or is that a whole different topic? thanks vince
You are an SPL freak??? Yeah me too. I would highly recomend a MMATS Juggernaut, a Kove Armagedon, or a digital Designs 9515. Also look into the L7s as you stated before. NOT the W7...there are a lot of better subs out there than the W7...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
When i would have 1st times in for bump, I would always set it to be safe in this case.... everything maxed out and not fry the subs. Enclosure...
10
vasvin99
vasvin99
dallas, PA
RangerMan
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
