I need some answers on Car Audio Help!
  • 3
rouskisman
Like above I need some answers on car audio.
I have just gotten into car audio, and need some help on what does what. If someone could email me or reply to this it would be greatly appreciated.
Amplifier -
2/channel
multi-channel
mono.
-Caps
-Crossovers
what should i look for in buying a subwoofer, amplifier besides the price and what not.
Low end means like lows bass ya know really responsive mid means more bass at a higher vloume and high end is the bass or loudness at its peak without distrottion but that really is not an easy way to exlplain to a newbie so basically you are wanting alor of bass with sound quality question answerd a pair or adire audio shivas and a jbl 1200.1 and that should sound awsome hope I helped.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
150
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
111
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
455
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
351
rouskisman
rouskisman
Greenville, South Carolina
jlman
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
