Need a little advice/help...
mariojas
Hi guys I have a quick question for you all: I want to get 2 Kicker 10CVT12-4-N which are 400watts RMS 800w Peak each single coil 4ohm . I would run them parallel so total impedance will be 2 ohm.
This is what I dont know. What amp should I get? the zx750.1 which has RMS 2 Ohms: 750 Watts x 1 Channel and peak of 2 Ohms: 1500 Watts x 1 Channel
or the dx500.1 which has RMS 2 Ohms: 275 Watts x 1 Channel (d 1% THD+N) and peak 1 Ohm: 1000 Watts x 1 Channel
I'm not sure Im getting mixed answers hopefully you guys can help me straighten this out..
Thank you
2 subs are 170 and the zx750 amp is 270. And that is my price range... unless if you have any better setup suggetions for that money? I'm open to suggestions.
I already have the car wired. I dont know I never heard of audiopipe... I'd rather pay more and get a brand named amp. What about subs? Do you know anything about them good/bad? or "better" ones around that price range?
The main reason bass boost isn't used is that it only boosts frequencies within a very small range, and often causes the amp to clip at a lower volume level than if the boost was off. With it off, you have a nice amount of mass over more frequencies at a higher volume, compared to a little extra bass at a certain frequency with it on.
mariojas
mariojas
Cleveland
disturbed471985
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
