My Build Log for Nick from ROE
Was a busy night lastnight. got all the wiring done in the trunk just waiting on the other 3000d to come back from db-r. it should be arriving tomorrow so everything will be ready to go once the wall is completed and i glass the doors. i say by next weekend i should have it up and playing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
got home from work and put the last amp in the back. body filled the holes on the baffle and sanded it down. started working on the doors. got them wrapped but not glassed yet. put the seats in for a test fit.
got a bit done. keep in mind this is not gonna be completely finished and made pretty by me. so the way it is pretty much is the way you are gonna see it at sbn and untill nick decides to go to town sanding and filling and everything to make it all pretty. i told him i would build the base for him and he could make it pretty after i was finished.
another layer of resin on the doors
this is how i keep the inside warm in order for the resin and paint to dry fast //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
wrapped the pillars and resined them and painted a couple coats on the baffle. had a little run above the point but o well haha.
well everything is hooked up and working. got the mids/highs tuned. have not messed with the subs because its too late at night to do it. but im happy so far. still have hours i could sit and tune the mids and highs but i think ive got them close. i took a vid of the mids and highs but i think i had my hand over the mic with the flashlight in my hand so it sounds kinda muffled. for some reason there is some rediculous turn off pop/squelch im not exactly sure what is causing it but im not a big fan of this eclipse dvd navi headunit. does not have enough adjustments for things.
doors before we put them back on. they are not getting finished by me but they will do for now.
so i got the subs loaded and hooked up and dropped the carpet and everything in.
ok the vid
couple quick tests playin bass mekanik - bass mekanik. also played around with a few other songs and it was doing over 150 from 35hz to 55hz. i was doing the same number at 44hz and 52hz from 2 songs i played. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif this thing plays 30hz like there is no tomorrow. cant wait to let nick show this thing off at sbn. ill get vids sometime this weekend probably. hope nick comes by and checks my masterpiece out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sealed on dash on bass mekanik
drivers door open on bass mekanik
well i took some videos tonight so its a little dark but u can kinda get the idea of it.
vid of just the system.
sub movin //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
GO COLTS!
2000LaDe
2000LaDe
Lafayette, IN
Brian_smith06
