Most watts I can have before dimming?
With my current setup, HC1400 in front and same alternator with big 3, i get dim at full volume.
Alpine PDX-4.100 and Orion 1200D powering a Kicker L7 at 2ohm(725watts).
Well, I'll have to try it then. I was going for around 2500watts, but guess that's not possible with my electrical system.
Why think in current? You should think in watts. Current and voltage are never constant, but your amps are trying to make constant power based in watts. If you only think in current, then you lose sight of voltage.
I would say that your system should be able to do 1400W at idle and about 2500W while driving without dimming. That is just a best guess. The only true way to tell is to test it out.
no clue, i need to test it out this weekend. will probably get a new alternator that does 300amps this summer if i cant use an orion 2500d.
Because not all amps have the same efficiency under load...
What the hell is a Jiggawatt?
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
Welcome. You have a Crown Vic, Which year cruiser is it? You have a trunk big enough to hold a family of four - why three 8's and not a couple...
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
Let's if i can give my input too. 180 Watts is the maximum power your speakers can handle. And it is 4 ohms. And you're trying to find the...
27
4K
Only a testament to their durability evl won't last that long id wait until the mojos gave up then go evl honestly and trust me unlike 99.5 of the...
36
6K
plyer3
plyer3
N Little Rock, AR
skmfkr
