ok, agreed. so please prove me wrong. here is what i need deafwish:
1) side post terminals along with top post terminals and the top post MUST have a cap to cover it
2) i need minimum 700cca and 900ca
3) i need it to be a lightweight performance batter, must be UNDER 35 pounds
4) i need to be able to be half way across the country and get a battery replacement the same day, and once inside the store within 15 minutes or so. something very easy like the battery i have pointed out thus far.
5) 3 year warranty MINIMUM
6) if it has all these features it needs to be cheaper than the optima for the deciding factor. if it is more expensive than obviously i would expect it to have ALL these features + some of them BETTER than the optima.
so now that you'd like to show me how i shouldnt have started this thread in the first place, please enlighten me with a battery like this. if you do, my hats off to you and ill bow down and admit openly on here i should not have put red top and yellow top as my only 2 options. fair? look forward to hearing back from you, lets see what you come up with since my battery options are so bad. i actually hope you do find me one with ALL of those features that is better, because then id buy it. however from my months of research, im yet to find a battery with all of that. thanks and good luck!
