good results with an aftermarket system with the 2025 Tucson bose system?
eckoh7
CarAudio.com Newbie
I have a 2025 Hyundai Tucson Hybrid N-line with the bose system. Has anyone added a system to this car (or the Tucson limited) and had good results?
I was planning on going high level out from the bose amp to a DSP amp (Audison/AF) and then obviously to aftermarket speakers but I'm really hesitant now because I'm not sure how it's going to sound. I'm nervous that without bypassing the HU DAC/DSP and the bose amp that the signals I'm putting into the DSP amp will be too processed/colored/filtered to get a good final product. There is currently no audio interface for the bose system (that I'm aware of).
Does anyone have experience doing what I'm planning? and how were the results?
Currently my plan is to just wait and hope someone releases an audio interface for this system so I can get a clean digital signal to feed the aftermarket DSP amp.
Do you know how to bypass a factory amp first of all? You won't be using the bose system now. You'll using the Audison AMP. Where's the location to the factory amp to your Hyundai? It's usually underneath the dash board near and behind the radio. A smaller looking amp. You'll be bybassing that. Many wires going through it. Basic info on bypass is you're taking the signal wires re-entering that from the factory amp to speaker inputs of the Audison. Special wiring harness needed or just buy and make the wiring and connections iso connections yourself.
Very good then. The Audison should to good. Make certain you check all the ohms on the factory speaker first. Usually or may not require 4 ohms, but if they do, then replace them. To 4 ohms. I don't know, but Hyundai is South Korea made. So, I didn't know they set factory amps to their cars, but if they do, then the above. DSP, Probably not needed because not that elaborate to actually use a digital sound processor.​
so, you're responding as if there is a way to do all that. yes, I know how to bypass a factory HU and amp. the problem is, that is not currently possible with my vehicle, hence my dilemma.
You should be ok. Many luxury vehicles come with the same dilemma of having heavily modified signals from the OEM that have been "cleansed" by high quality DSPs. Audison is one of the favored ones so you are on the right path.
eckoh7
CarAudio.com Newbie
eckoh7
Los Angeles
1aespinoza
