MidRange/MidBass 6.5s that like 250-350 watts @ 4 ohms???
  • 4
Just like the topic says, i've done some searching around the forums (yes, some noobs actually use //content.invisioncic.com/y282845/emoticons/search.gif.e79a63b2b580b39b282dff402646b704.gif ) but haven't really found any definitive ideas besides possibly higher-end Boston speakers?
I'm looking for a pair of 6.5s to go with my Aura RPM Stage 2 tweeters that will REALLY like 300ish watts @ 4 ohms, that will pound midbass down to 70hz but can run mids enough up to a comfortable tweeter point. The Stage 2 tweeters are pretty beefy. Again, just looking for the 6.5s, NOT a full component set. I'm planning an active xover so i dont need passive crossovers anyway.
Price range doesn't really matter, obviously the cheaper the better but i'm really going for something good to avoid having to do a 3-way set up, so throw out anything.
I'm thinking my best bet would be to get a pair of 6.5s that originally were a part of a component set, like just the woofers from a BA Z6 or a Pro60 set, or something like that. Maybe there's a good midrange driver not a part of a comp set out there though???
Thanks to any replies.
Only Diamonds, the other's I have heard good things about. I heard a set of CDT's a while back, they sounded underpowered and flat to me.
And I have Boston's and they are great with power, My rally's are rated to 275w but only get 100 or so not, but I hooked em up to 150ish and they sounded 50x better.
Yeah, i really like the idea of the Z6. Price is very high though, i don't think i could afford it //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
I'll look into the RC620 then...
Any one else have any suggestions?
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
11K
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
I know, generally speaking, that doing what you’re doing will give you some semblance of what the end result “should” be. That said, driver types...
Worth it? That depends on your thoughts. When I upgraded from 2 way to 3 way I was very happy, but when I did that I made pods and moved speaker...
twoohfour
okay
twoohfour
Where you live (Ex. Los Angeles, CA)
squeak9798
    Jun 15, 2024
    Jun 15, 2024
