Mdf build with no screws
mrpep
I built a birch box once held with only glue and Brad nails and worked out real good. Today I plan on building with 3/4 mdf and would like to use glue and Brad nails again. Anyone ever have a bad experience doing this ?
I have a video somewhere of me having to fix a mistake on an mdf box. Pulled the screws and the mdf came apart so easy I recorded how easily the box could vibrate apart at the seams. Trying to find it.
I have done 155db builds with just glue lots of times. Just make sure you clamp and give everything time to dry
The above video was a heavily glued mdf joint that had screws clamping it together for a week. I pulled the screws out and it took maybe 10 lbs of force to separate the joint.
Seems I should be ok by Many of the replies. I did use a brad nail gun too by the way so I'm hoping I'm ok.
mrpep
mrpep
chicago
mrpep
