MazzaSEC Build log! Sundown, Fi, Deka, PG RSDS
Battery bank is done! Its late so the pics are kinda dark. I will get a pic of the 34 under the hood tommorow.
you wasted alot of wire on that, i mean not thats its alot but copper isnt cheap these days, If I can save a foot then thats money to me. Glad I bought a 100ft roll last year. But other than that get the ******* box in.
hahaha, man unless you got a special edition Explorer with wider plastic pieces this will not fit inbetween
I just measured again.....45in is not inside the plastic piece.....and 33d wont fit with my Powermaster D3100 in same spot as ur deka.....33d is like way on the plastic piece from my D3100 case
Get my a pic of your measurements pleaseeeeee
Just look at your batts, thats 39in right there and you barely have room left
I'm anxious to see and hear this man :)
And why poor, poor guy?
Skip, It's going to be the tightest fit imagineable, I do believe, but they think it'll fit so let them try, hell it cant hurt nothin
He'd have to make a whole new box.....just a pain for being like .75 in to big in some areas
And it curves to smaller at the end......ill wait to see him measuring in a pic if he can get it
Just took measurements and it fits. If anything where it curves at the end it barly needs to be cut around the curve. Mike should be posting a pic shortly. But it definetly will fit.
Here measurements with the batteries in
when the top closes does it extend past that point, and also you are doing subs up port back correct, well if so there wont be any room between the port and the back of the vehicle wont that not work that good
mazzasec
Banned
mazzasec
ATL
Rawr-DQ
