Making my car loud
If that sony h/u unit is a higher end model i'd stick with that. Then Get 2 sets of int speakers ( new or used), mtx 1501d (1500rms@2 ohm, 2000rms as low as .5ohm modded) used for $250 and then 3 dual 4ohm 12 or 15" subs of your choice. Wire them to .67ohms and be happy.
Buy used and you'll save alot and be alot louder then buying new obv..
so......
250 amp
70 on 2ga install kit
100-150 int speakers
300-350 on 3 subs
thats roughly 750..Find a local member willing to help and Throw him a bill or 2.
I think the BL, BTL, and DD3500 are a bit much when considering a budget build. All of those like good amounts of power.
A BL and an AQ1200d would keep him around $500-$550 if bought brand new from the respective companies. Leaving $200+ for box materials, wire and accessories. More than doable. Hell, could even throw in a Shuriken battery and still be around his said budget.
I've done many budget builds, with many goals in mind //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If that sony h/u unit is a higher end model i'd stick with that. Then Get 2 sets of int speakers (used), mtx 1501d (1500rms@2 ohm, 2000rms as low as .5ohm modded) used for 250 and then 3 dual 12 or 15" 4 ohm subs of your choice. Wire them to .67ohms and be happy.
Nice amp, but I would not recommend that ohm load for daily on stock electrical.
A BL and an AQ1200d would keep him around $500-$550 if bought brand new from the respective companies. Leaving $200+ for box materials' date=' wire and accessories. More than doable. Hell, could even throw in a Shuriken battery and still be around his said budget.
I've done many budget builds, with many goals in mind //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif[/quote']
Not a bad option there. Just depends on what he wants. Single or dual 15/12 setup. The AQ is a good option for power though.
silentcrow
silentcrow
Springfield, MO
CHEMMINS
