LOUDEST setup possible, help me out? Hummer H3 **have fun with this**
6 sundown nightshade 18's ported clamshell tuned to 40hz...walled....with 6 sundown
saz3kd's 1ohms ..use maxx link and upgrade ur volts to 16volt setup....and theres ur 160+ bass racer
80
I dont think this guys really knows what loud, loud is...
I bet you sit him in a car 140-145 (on TL) and he'd be like OMFG..//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
for reference, the stereo in my signature ran between 4-5 grand, and me doing labor.
you can get away with a good 2000-2500RMS without modding the electrical system too much. As soon as you get into the 3000RMS+ watts range, a huge portion of the cost of the system goes into electrical.
2 Critical Mass UL12s or 2 15 DD 9515s would be sick! The UL12s will get f-ing loud and sound good doing it. And the 9515s are just great SPL subs. Both are a bit pricey but well worth it.
they are good on music as well depending on your enclosure
If you want to do four 18's then 4 nightshades will fit the bill since you can put them in 4 cubes each and they will perform well. If you can find 4 TC sounds Lms 18's that will pound and sound supurb. Both the nightshades and the Lms subs can be powered buy four sundown saz 3000's. That's one saz 3000 for each sub. The F.I. btls are good as well and the RE xxx subs are nice and will take the saz 3000 with a smile
no the xxx will not.
new, old, any, it wont like 3kw+
so you think I could run 3000 watts of stock electrical? If so, that's what I might be leaning toward. I just called him and he said he doesn't want to spend much more than a grand lmao. Major letdown eh.
no
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
734
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
benner410
benner410
Houston
SneaksFiend
