LOUDEST setup possible, help me out? Hummer H3 **have fun with this**
benner410
If you had to put the loudest possible setup in a a cargo area of a hummer h3 with these dimensions, what would you put? This is for a friend.
^^The rear seat can't be down, it has to be in the cargo area behind the second row.
I need to know subs, amps, box dimensions, etc.
2 21's? 3 18's? I'm not the most experienced with car audio, so help me out please. It needs to sound good, but I want high SPL. Thanks!
18 - 20 cubes - 300 sq inch port
3 - 18's of your Choice (DC Audio)
3 - Sundown SAZ-3000
2 - HO Alts (DC Power)
5 Batterys of choice (PowerMaster,Kinetik)
Good Power Wire 1/0
Big 3
MissingLinkAudio
Wall it up
155+
That is just depending on your bank account, lol
Good Power Wire 1/0
Big 3
MissingLinkAudio
Wall it up
155+
thats the key, you could put 20,000$ into it, or you could put 1500$ into it, a budget is severerely needed.
i mean, 4 sdc2.5 15's off a zx2500.1 would be rediculously stupid loud and not break the bank too hard
or you could do 8 hdc 10's off of 4 ia 40.1's and it would be unbearbly loud to the point where you would never turn it up that loud anyways and you get the fun electrical task of supporting 16k watts, which im thinking 8 kinetic HC2400's and dual 300amp alts. how insane do you REALLY want to go is the question
If you want to do four 18's then 4 nightshades will fit the bill since you can put them in 4 cubes each and they will perform well. If you can find 4 TC sounds Lms 18's that will pound and sound supurb. Both the nightshades and the Lms subs can be powered buy four sundown saz 3000's. That's one saz 3000 for each sub. The F.I. btls are good as well and the RE xxx subs are nice and will take the saz 3000 with a smile
Ok after reading these past few posts, I think i DO need to narrow down some things. I don't want 5 batteries, and a dozen alternators (exaggeration, but you get my point). I also don't want him to have to spend a ridiculous amount of money. I was thinking a subs facing up setup. I'd rather not have to build a wall. Also I would like the most "wang for the buck", lol. He wants his ears to break, not his wallet. If that's even possible....
Keep the rear seats,
4 Sundown Nightshade 18's ported in 5.5-6^' each
8 Sundown SAZ 3000d's
this would be pretty freaking loud and still have the full use of your seating capacity.
Takes power to make power, for what it sounds like he wants you can go cheaper subs but I sure wouldnt cut it short on the Elec side of the build.
All at window line
AudioQue Subs 4 - 15's
2 - AudioQue 3500's
3 batterys
1 HO Alt
2-18" D2 Sundown Nightshades,
2-Sundown SAZ 3000d.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D
You will need a High output alt. and 2-3 good batteries to get loud. sorry:crap:
benner410
benner410
Houston
SneaksFiend
