loud option on headunits?
I don't believe that the loud option will harm your system. I have a head unit with the loud option on it, and i have a sub that I run 320 rms to, and have had no problem with the highs. I just spend time tuning my eq settings (not to say that you don't). If there really is a problem, i'm not sure what it's with, but i highly doubt it's with the loud.
depending on the brand of your h/u...i had a pioneer...and w/ the loud...what it did was boost a particular freq. range.....and it lowers the others...like it u set it on low...it would boos the low freq. and lower the high and mids...
Will not harm altho if you want your mid and high to keep in balance with your subs then its much easier to drop the loud function and put in and remote bass controll unit which basically does the same but on a better frequenty/hertz level then loud gives you.
today sux
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
957
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
5K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
JonBoy
JonBoy
Lexington, KY
moskey71
    May 18, 2024
    May 16, 2024
