SicAudio
did you fart dude?
Porting tips:
Keep the port(s) as far away from the enclosure sides and back as possible except for the slot type port.
Make sure the inside end of a tube or square port is at least the equivalent of one vent diameter away from the back of the box or any bracing materials.
Keep the vent free from anything that may affect air flow through it.
The port should also be placed as far away from the speaker cone as practical.
and this came from "The Cookbook"
Fb - is the tuning frequency of your enclosure in Hertz.
Lv - is the length of your port in inches.
R - is the inside radius of your vent tube.
Vb - is the internal volume of your enclosure in cubic inches. To convert cubic feet to cubic inches, multiply by 1728.
If you want to use multiple ports, divide your enclosure volume by the number of ports you want to use, then use the result of this calculation as your Vb in the formula below to find out how long each port should be .
If you want to calculate square vents, the formula below will give you the value of R to use in the formula above.
In the formula above, a is the area of your square vent (height x width), and (Pi) is approximately 3.141592.
