LIMITING a sub's output
I'm getting the W7 because I want high sq combined with great spl. I dont really plan to have the bass up real high very often, but I want the potential there if I ever need it. Long sub life is a very big priority to me.
So how can I set a general limit the output of the sub (that wont clip) in case I bunp a knob or more likely some fool comes in there and decides to see how hard he can blast it? I want to avoid the excursions that can damage or wear the sub.
//content.invisioncic.com/y282845/emoticons/chicken.gif.218ea7401db50d5e31a7e0b37e05e21e.gif
Set the gains properly...
Then you can have it on full volume with no problems.
I set my gains by listening levels(balance) with the hu sub setting at 0 (-5 to 5) then tested the output of the amp with a dmm to see what number on the sub setting produced my desired "max" rms. turned out to be +3 with volume at 58/62
sure you arent getting the w7 because you touch little boys? that is more likely.
So get a Fi Q , you obviously know very little and have been impressed by the high price tag and great advertising from JL audio - there are plenty that cost less and are ver capable products
SI Mag
Image Dynamics Max
Fi Q
Alpine type X
You use a Digital Multimeter DMM to set your gains on your amp and then don't turn it up past that - if your friends insist on fvcking with your stereo tell them to fvck off or walk.
Hang out here for a week and read posts and ask questions - in a week you will spend half of what you thought and get a system that is geared for your listening style.
killdevil fox
killdevil fox
Pumkin Peak, Appalachia
skateboardkid
