Is this a good battery diagram/battery bank
Then again, you wouldn't make a battery bank like that if you weren't competing in competition.
oh im not competing...its a bunch of ryanm923's batteries that i can get really cheap...i might use 8 so yeah its that many for the price of one kinetik2400..and i think more power
Your gas mileage may decrease a lot though. I can get batcaps for the low so I got plenty of energy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i only get like 17-19 anyways...v8 ftl...but i dont drive far by myself...usually have someone to split gas...
my accent is only v4 1.5 liter and got the gaz comsuption of a little pick up ftl //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
you too huh?...
I average 17-18 mpg because I drive like a granny. But that means I get to spend more //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif on car audio //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Actually, your drawing has some flaws.
You should always balance the charge and draw on your bank. If you charge at one end and draw on the other end, you are not spreading out the charge or the draw. The first battery would be charged more than the last and the last would be drained more than the first. The above graphic shows the proper way to balance both connections.
//content.invisioncic.com/y282845/emoticons/ohsnap.gif.17c4c91be09a7a4a3995fb7145adac39.gif
You always surprise me.
And by alt-, they mean ground, right?
I agree.
It is good to try and spread the load over the batteries in some form. In the OP's form, if he has a lot of current draw between the batteries and not too thick of wire/buss bar then that wire will heat up and cause resistance.
hrtbrk1
1ManWreckinCrew
hrtbrk1
Boomer Sooner, OK
loopkiller
maylar
    Jun 2, 2024
    Jun 1, 2024
