Installing Component Speakers - Genesis Coupe
  • 4
David88
Hey all. I'm not experienced with audio equipment and I've come across some issues with my installation process.
Car : 2014 Hyundai Genesis Coupe Rspec 3.8L (Without upgraded sound from factory)
Head Unit: Sony XAV-AX1000
Mono Amp: Phoenix Gold d.1000
Subwoofers: Phoenix Gold 12in 500 watt RMS each
I am Installing components for front door:
Polk Audio DB6501 6.5"
And coax for the rear:
Polk Audio DB652 6.5"
I started with the front. I have two stock lines to each door. One for the stock tweeter and one for the stock 6.5" woofer.
I tried connecting both lines into the crossover input (this input only has 1 set of +&-) and then of course for the 2 outputs I connected my new woofer and tweeter. I noticed that the woofer wasn't being powered well. I connected the stock woofer again and it was much louder and more responsive.
Did I connect them wrong or is it because I need an amp sending the approximate 100 watts RMS to this new speaker?
Any help would be much appreciated. I can provide photos if anybody needs a visual.
I would advise an amp on those . Your midbass response on the top polks will
Be better. Also you got 1000 watts in a coupe. It will ensure your front stage can keep up
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
David88
David88
California, US
MichaelEvanchuk
slater
    May 2, 2024
slater
    May 2, 2024
