I'm new and looking for advice based on my budget.
Had a few Amp and Sub related questions:
I if I get two 4 ohm subs rated 50 - 300 watts, and then I get a mono sub that says "300x1 @ 4ohms", does that mean each sub will only get 150 watts?
If a sub says 50-300 watts and only gets 150, is that really bad, or will it still perform pretty well, just not the best it could?
In such a case would I be better with one sub, therefore it gets 300watts from the amp for itself, or would I be better with two subs getting 150 watts?
yes
depends on the effiency of the sub. some will suffer some will play fine.
imo one sub with the head room is better then 2 subs starving
Ahh, not quite.
The amplifier does 300 watts RMS @ 4 ohms. The subs are each 4 ohm subs, which means you wire them in either series or parallel to a 2 or 8 ohm load. That means you'll either do ~500-600 RMS through them total, for ~250-300 apiece, or ~150 RMS through them, for about ~75 RMS apiece.
However, the amp needs to be stable at 2 ohms. If it's a two channel, it will likely only be 4 ohm stable when its bridged, so you would need dual 4 ohm, to wire each sub in parallel to 2 ohms, then in series with each other to 4 ohms, in which each would get 150 RMS.
That just went flying way over my head.
It's a mono amp by the way.
Check out this wish list, notice the mono amplifier I chose... I know the guy has it in stock so that's why I picked that one. But you then explained to me that it would be starving the subs of power. :[
WISH LIST - http://www.crutchfield.com/S-fSzFUBd9ivr/cgi-bin/wishlistviewer.asp
This wishlist is NOT going to be ordered off the internet. I'm using crutchfield because they are closest to store prices, therefore it gives me an estimate of price. It also helps me pick some of the brands that the store has... though i'm not positive of which he has.
I know for a fact that the store i'm going to buy the stuff at has:
JL Audio
Kenwood
Boston Acoustics
Alpine
I'm sure they have more, these were just some of the brands I saw while he was going over options with me.
Maybe someone could help me pick out a list of those brands for around $1000-$1200 tops on crutchfield? Or maybe just modify the wish list I just posted a little bit?
(by the way, the head unit is 100% now, that is the head unit I am getting.)
EDIT: Pluto, I just re-read what you said a few times and it made a little bit more sense. So, in theory, I could wire my amplifier as a 2ohm even thoough the subwoofers are 4ohm, and that would give them nearly double the power? Is that possible with the amp and subs I posted?
Yep - I'll try and explain it better when I get back in a little while //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif The electrical details of it all.
im probly going to catch alot of flack for this,
but I realley like my kicker ds 6930 speakers.
they sound great off 75w each.
I saw a fiew pages back people recomending you $300 component speakers.
is a bit much to pay for them I think. for $120 you should be able to find some
nice sounding stuff. and still have extra left over for other parts of system.
I also use kicker 350 4 channel amp to power my highs.
pair of the kicker ds 6by9 in the rear, and a pair of 6.5 in the doors.
I realley like that amp. it does a good job running at 4 ohms. - still clean
altho I have heard that it gets muddy when you run 2 ohms to it.
and
for a bit - before I had door speakers installed - I was running one channel to the highs
at 75w each speaker, and running another channel bridged to a small sub @4 ohms = 175w of power for the sub. - and it sounded great like that also.
not a knock your socks off kinda thing - but definately good sounding music.
Honestly, I don't need the electrical details as much as I need the application of what you said to my current situation.
I say this only because I don't want you to go wild posting a whole lesson when I know it will only confuse me and/or be irrelevant to helping me pick speakers. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Maybe you could, instead, tell me if I can apply the strategy you said to the subs and amp I posted above - the kenwood mono one and the two JL Audio ones.
EDIT: It says 500w @ 2 ohm, does that mean I can wire it down to 2ohms to get 250 w to each sub? That wouldn't be nearly as bad. If that's the case, should I go with the setup I posted in the wishlist above?
In case the wishlist doesn't work:
_______________________________
Kenwood KAC-8104D Mono subwoofer amplifier - $199.99
500 watts RMS x 1 at 2 ohms
Boston Acoustics SX50 - $199.99
5-1/4" component speaker system
Kenwood Excelon KDC-X492 - $169.99
CD receiver
Kenwood KAC-6404 $149.99
4-channel car amplifier
40 watts RMS x 4
JL Audio 10W1v2-4 - $119.99 x 2 = $239.98
W1v2 Series 10" 4-ohm subwoofer
Boston Acoustics S55 - $99.99
5-1/4" 2-way car speakers
$1,059.93 subtotal
$350.00 installation
+$119.84 tax
$1529.77
(not 100%, I want opinions on this - If I wire the amp to 2 ohms to the subs will that make the RMS 250w to each of them?)
Good luck with everything roper, sounds like you've got a nice system picked out. Wish you could've gone with my buddy, it would've saved u a little bit of dough and you could've got high end brands. I'll pm you his number if you change your mind. Just another option for you to consider.
roper
roper
Long Island, NY
Plutoman
