how to tell what a box is tuned to
Isn't a subs motion at minimum at the tuneing freq.Not to thread jack but it might help a bit.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I really don't know what to say.
At least making such a big box means you're making the most of the **** power you're sending the sub.
Which is also dangerous because the cone is no longer supported by the enclosure.
it's held up through a few dozen songs so far, would there be any early warning signs from the sub?
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Please don't tell me about learning and needing to design first, as I think I invented that category, as I'm fairly positive someone will prove via a certain picture.
Love,
CJ
After watching the video, I actually suggest that you throw the box away and make a new one. The joints are flapping which looks like it's causing a loss of pressure. That's the entire theory behind a ported box, and if the air within the enclosure cannot support the cone, you can damage your speaker. That's what I fear from this.
do i need moar caulk?
Just get a hammer and smash it up before you try and take it out
hmm, that would work. im looking to replace this sub anyhow, what if i just plugged it up to a 220 plug in? i wonder if the sub would go before the box blew apart or not lol
If you want to set your house on fire go for it. Otherwise I would not advise it.
And dude, get someone else to build the box for you.....
Without a photo this is the best I could come up with, note the "physical port length" is at 22.5" and if you measured down the portwall to get...
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
444
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
Hydrastas
Hydrastas
NE ks
Hydrastas
    May 24, 2024
