How to run 2 0 gauge wires from battery terminal?
CarAudioNewbie9
I am looking to run a second run from my battery but I have no more slots on my battery terminal. My batt. terminal is two 0 gauge, one 4 gauge, and one 8 gauge. One 0 gauge is taken for the big 3, the other is taken for wire to amp. I am using distribution block but I am simply looking for another run. How do I do it?? Do I have to have a battery in the trunk? Are there any battery terminals that would work?
Take the battery terminal off and just use the posts? I never understood those battery terminals. Seems like one of those marketing things to make money.
But how do you connect it to the terminal then?
For a visual reference; http://www.caraudio.com/forum/car-audio-build-logs-*new*/465696-dsmdans-05-ram-quad-cab-blow-through-build.html
You can pick up terminals just like that at Autozone for $4.99. I was just in there today trying to find something and saw a whole bunch of terminals.
Go check out the terminals at Autozone. You should be able to fit what you need on there. Longer bolts should be available at your local hardware store if you need it.
CarAudioNewbie9
CarAudioNewbie9
BFE
Imtjnotu
    Jun 20, 2026
    Jun 20, 2026
