how many db 4 12s
Your not fitting an 18 in an eclipse like yours with proper space requirements in the trunk. I have been there, trust me I took all the plastic out the hatch and even cut some bracing on the car and the box still wouldn't fit, and 2 is out of the question unless your doing a wall. I am even curious to see you fit 4 12's in there with proper space. It can probably be done but I would like to see how to get an idea, as I might like to do that also.
is the hatch area smaller even with the seat down than the sec gen eclipse? uve seen that vid with the 2 18" LMS Ultras in a sec gen with proper space?
These cars **** for space. I think my measurements without the plastic were 34" wide 22" length 15" height. With the plastic in I would probably subtract 2 inches all the way around just to allow room for error and curves.
if this is close to yours go with the 12's
assuming length is depth
No 15" is depth 22" is like the left and right sides. It's actually like 18" from bottom of trunk to top with the hatch closed, but then again I had the plastic covering off the lid of the hatch, I even had to take it off for the enclosure I have now for it to fit.
ok, well chase if you get some measurements I will suggest what size subs.
chasepb
chasepb
cameron,NC
mlstrass
BP1Fanatic
BP1Fanatic
