What you're saying is that I'm reading it wrong. The "50-500Hz" spec just means the cutoff range, not necessarily the max range when in HP.When you enable HP mode the amp will put out all freqs from the HP cutoff to 20Khz. When you enable LP it will pass all freqs from approx 20Hz up to the LP cutoff.
You won't hurt your mid woofers running then from 80hz to 500hz, but you might miss out on some freqs above 500hz if they aren't covered by other speakers.
What other speakers are in the car and where are they located and do you know what freqs they are cut off at? Sorry I'm not familiar with that car.
the subs wont blend at all, if two different size subs play the same freq at the same time it will sound like crapola.
do you have any tweeters in the car? i'd suggest you do a search on active component speakers
