High level inputs
TripleT1414
Id like to hook up my 2 powered subwoofers from my old truck in my new truck. The problem is id like to keep my factory head unit. Id like to use my subs high level inputs but am a little confused how if go about the process hooking up the 2 subs this way. Ive managed to power the one but am stuck on the solution to get the other going with it.
For power you can use a distribution block to share the battery cable to both subs. You can also use large wiring nuts to splice with the positive and negative of the other sub since they use 14 awg and thinner.
For signal you splice into the rear left and right speakers. Use a thin wire like 16 or 18 awg for easier splicing, running, hiding. I do not suggest sharing signal since most music is now recorded in stereo.
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
505
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
483
You need to set the high pass filter for your 6.5" speakers. I wouldn't run anything lower than 80hz. 100hz would be alot safer. Adding a...
TripleT1414
TripleT1414
Canada bc
    Apr 28, 2024
    Apr 28, 2024
