High level inputs
TripleT1414
CarAudio.com Newbie
Id like to hook up my 2 powered subwoofers from my old truck in my new truck. The problem is id like to keep my factory head unit. Id like to use my subs high level inputs but am a little confused how if go about the process hooking up the 2 subs this way. Ive managed to power the one but am stuck on the solution to get the other going with it.
For power you can use a distribution block to share the battery cable to both subs. You can also use large wiring nuts to splice with the positive and negative of the other sub since they use 14 awg and thinner.
For signal you splice into the rear left and right speakers. Use a thin wire like 16 or 18 awg for easier splicing, running, hiding. I do not suggest sharing signal since most music is now recorded in stereo.
TripleT1414
CarAudio.com Newbie
TripleT1414
Canada bc
1aespinoza
