hifonics maxximus vs incriminator audio 40.1
Yehhhh.....their not strappable:p:....but good try
Next door neighbor has 2 40.1s strapped at .7(.35amp) and they rise to about 2.2ish and make 7500 between the pair....sooo decently underrated...3600@1ohm and it does that power @2ohm
Id say 4200-4500 at 1ohm reactive isnt out of the question for these amps...but all what the others have said
****it forgot about that
Actually they are strappable using a MaxxLink. And I have two Autotek MM4000.1Ds that I got for a hair over 1000 shipped. Can't beat it with a dead hooker.
i just got the maxximus specs and at 18 volts you get15,200 watts so with 2 40.1s you get a few hundred more watts for less money(well depending on your skills because nick said at 18 volts 2 40s will get you 15-16k watts) does anyone know what kind of current draw the maxximus has?
These are our 2 biggest amps (for now).
There is also a 3000, 4000 & 5000 watt models as well a 2 great class A/B 2 and 4 channel amps which feature absolutely incredable SQ.
Note: These measurements were made at .1% THD & N.
These measurements are made at standard impedances.
Can you imagine if you lowered the impedance?
XXVSampson
13.8 V / 4-Ohms: 2600 x 1
13.8 V / 2-Ohms: 4500 x 1
13.8 V / 1-Ohm: 8000 x 1
16 V / 4-Ohms: 3500 x 1
16 V / 2-Ohms: 5400 x 1
16 V / 1-Ohms: 8900 x 1
18 V / 4-Ohms: 4800 x 1
18 V / 2-Ohms: 6700 x 1
18 V / 1-Ohm: 10,200 x 1
XXVMaxximus
13.8V / 4-Ohms: 2 x 2000/1 x 7000 bridged
13.8V / 2-Ohms: 2 x 3500/1 x 10,000 bridged
13.8V / 1-Ohm: 2 x 5000
16V / 4-Ohms: 2 x 3100/1 x 9000 bridged
16v / 2-Ohms: 2 x 4500/1 x 12,600 bridged
16V / 1-Ohm: 2 x 6300
18V / 4-Ohms: 2 x 4600/1 x 12,200 bridged
18V / 2-Ohms: 2 x 6100/1 x 15,200 bridged
18V / 1-Ohm: 2 x 7600
well the 40.1 is at standard impedance as well."on 18 volts expect 15-160000 watts" so the same thing can be said about the 40.1(a strapped pair by the way)can you imagine if you lowered the impedance on that????
Nick never said anything about what impedence. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I can flat out guarantee that a pair of 40.1's strapped at 2 ohms (1 ohm per amp) is NOT going to produce 15,000 watts.
1 ohm is their rated ohm load but it's pretty common knowledge that to get more than rated power out of them you're going to have to drop the ohm load down to at least the .5 ohm range PER amp.
your right he didn't say anything about impendance....so how can you asume that it is below 1 ohm¿¿¿¿¿¿
Because I know enough about their performance that I can accurately describe what kind of conditions you would need to get that kind of power out of them. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ask anybody who has ran them what kind of nominal ohm load they used to get more than rated power out of them.
ghettoknock
ghettoknock
lebanon
OldSchoolBass-G
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
