help wiring my speakers to amp (Hifonics amp + Beyma speakers)
alanj
Hi, im new here... my name is Alan, from Dominican Republic... i have a 2011 camry
i need help wiring my setup, and choosing the rest of my components.
So far this is what i have:
(1) Hifonics ZRX1000 4ch amp
http://www.sonicelectronix.com/item_...ZRX1000.4.html
(4) Beyma 6.5" speakers
Beyma Car Speakers - Beyma Pro 65ND lightweight neodymium midrange 6.5" speaker - Beyma Pro 65ND 200 watt neo 6.5" car midrange has a high efficiency of 100dB SPL. Beyma Pro 65ND and other Beyma 6.5" car speakers here.
spec
this amp is rated to 125W x 4ch @ 4ohm and 250W x 4ch @ 2ohm
500 x 2ch @ 4 ohm bridged
my speakers are 4 ohm each, and can take 100Wrms
the question is, can i wire 2 "4ohm/100wrms beyma speakers" in parallel to CH1 and 2 more "4ohm/100wrms beyma speakers" to CH2?
wired in parallel, will draw the ohms down to 2ohm, each pair receiving 250wrms.
AND SECOND, one 12 - 15" sub (which i still don't have and dont know which one to choose) wired to CH3/4 BRIDGED receiving 500Wrms @ 4 ohm
is this setup ok? am i demanding too much to my amp? everything is being done according to specs.
thx up front
You are expecting too much from that particular amp to power 4 speakers and a sub.better off just with the four 6.5s on that amp and getting a mono amp for the sub
decided to swap rear beymas with Full range 6x9 speakers or 8" mids, and wire 1 speaker to each CH @ 4ohm putting 125Wrms on each. And later on, a sub with separated amp.
my front doors Beyma speaker Frequency Response is 150Hz - 8.0kHz, to what Freq. range should i EQ my front speakers, if i install full range or mids on the rear deck... im just asking for a baseline starting point.
I think most people start with 80Hz and below for subs and 80Hz and above for mids.
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
613
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
975
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
alanj
alanj
Dominican Republic
Da64u
    May 24, 2024
    May 23, 2024
