Help!!! New enclosure for level 5 12's in a 2014 charger!!
  • 5
After I get the dimension of the enclosure how do I calculate the 45's in ?
Calculate a rectangle and divide in half. You only need to know the height of the box and the size of the corner.
16" tall enclosure with wall thickness(.75) subtracted = 14.5"
IF your 45 has a 2" side and a 2" side your formula looks like this 14.5 x 2 x 2 = 58 cubic inches
YOU must divide in half to get a triangular shape 29 cubic inches
Convert cubic inches to ft since your working in cubic ft 29 divided by 1728= .016ft^3 per corner
DO NOT subtract 45 volumes in ports. The port has alrdy been displaced.
Subtract .016 per corner from enclosures net volume.
thanks bro!!!
---------- Post added at 09:29 PM ---------- Previous post was at 09:28 PM ----------
Thanks Time to get extra LOUD!!!!! Lol
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
HI-C
HI-C
Las Vegas
HI-C
Decebal
    Jun 10, 2024
