incorrect, the yellow wire must have 12v constant, red gets 12v switched. Black is ground. if your unit is not turning on you will need to test with a Digital multi meter($5 at harbor freight tools) to make sure you are getting voltage to both of these wires.those wires should not matter. the red and black are really the only ones that should effect that.
He's on the money dude. And GM hasnt changed anything in years as far as electrical goes like FenixAudio said. And if it doesnt work at the harness have you tried hooking it up directly to the battery? Or in another car? If it was me, Id let you try your deck on my harness cuz thats what friends do...incorrect, the yellow wire must have 12v constant, red gets 12v switched. Black is ground. if your unit is not turning on you will need to test with a Digital multi meter($5 at harbor freight tools) to make sure you are getting voltage to both of these wires.
the orange wire is not needed, all it does is dim the head unit when the lights are on. the pink wire if audio interupt for adding a bluetooth unit to the deck.
are you installing the deck in the 99 malibu? if so this is not a tough ting to do. i can give you all the wire colors from memory ifyou need them. every gm has been the same since the year 1. let me know if you have any questions. my info is on my wed site. fenixaudio.com
Dude, its not a problem FenixAudio! On this site I only want to be professional when I give advice or help people out like this. I suggested the battery thing because its a direct power source, and would help him figure out the problem. If you have any other problems or anything kr15, let us know. We'll help you.thanks for the back up crysismaker ive been doign this profssionally for 10 years, and im mecp master certified. i can answer jsut about anything.
yellow 12.2 or above with car OFF 14.4 with car onYes get the DMM. Test the yellow and red for starters and see if they have power. The ignition wire as you may already know should only have a current when the key is on. It should read around 12v when the car is off, and should read anywhere from about 12.5 to 14.4v when the car is running. When you get the DMM, let us know what your findings are if you need more help.
You welcome for the help kr15.
