Grounding questions
  • 2
imsickofweed
Should my amp, and hu grounds be connected together via cable and then to the battery? Right now I have my amp grounded to the passenger seat stud and the hu is grounded to the factory ground screw behind hu. Should I run a cable from the amp to the ground screw behind the hu and then to the negative side of the battery? Ive done the big 4 and have 0 gauge welding cable from alternator case to engine block to neg bat and a 0 gauge from alt + to pos bat and then to amp +. If I did tie all the grounds together would that help my amp voltage or cause ground loop whining?
nope keep the headunit grounded to the sheetmetal behind it, and if anything just run a 0 gauge wire from the amp to the battery negative terminal.
small loads like a headunit or amplifier that pull less than 100a really dont need dedicated ground runs or connections like you're talking about 99% of the time
The amp is mounted under the passenger seat so the hu is on the way from the battery to the amp. Would it hurt anything or is it just not needed but still might help a teeny tiny bit?
I just started a build log and I hope everyone will come check it out. I have a few threads going, but they all pertain to my build. I have a link in the signature.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
Oh ffs...he's jumped a car twice and is now an expert on car electrical systems 🤣🤣🤣
963
I had a really hard time with my 1990 240sx. That had to have been the hardest car to wire up and install to date. The doors were something else
imsickofweed
imsickofweed
Orange County
imsickofweed
    May 24, 2024
    May 23, 2024
