Good 12 subs to run 1400 rms
In most cases I would say run Obsidian or sundown or similar. However you are tight on space in the integra. So I would go DC which likes smaller enclosures. Assuming the budget allows of course.
sundown likes it small to //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif around 1 cube per
You could get 3 12'' MB Quart RWE 302 subs for under $200 from woofersetc. Rated 500w each & are the true German made Quart. They sound very' date=' very good. Would be louder than a pair of SA12's on 1400w. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif[/quote']
idk about being louder than the sa 12s. Maybe if they were ported but op would need a huge box for that.
Sundowns and skar are nice but your going to need more than that 1400 watts to run them well i'd lean more toward the skar thinking they wouldn't be as underrated as the sundowns are but not sure. There's a crazy deal anyways for skar where you get 2 SKAR 12s in a custom made box for $359.98! *2* SKAR VVX 12's+ Custom Ported Box **SPECIAL** $359.99 Shipped - Car Audio Classifieds
well I do think he has enough power to run the skars and the deal you linked is really really good, I think the biggest problem is the amount of room the OP has to work with.
I have 2 skars in a ported box and the gross size of the box is 6.5 cubes, they like a large box, larger then what the OP has to work with. IMHO
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
707
Robert 2001
Robert 2001
Lakeland, FL
mclerico83
Decebal
    Jun 10, 2024
