Good 1/2 Ohm Amps?
whats your budget?
I would highly suggest you upgrade your alternator if you haven't..
its risky using an amp not designed for the load with a struggling electrical system.. your much better off with a more efficient and less strenuous design for the electrical system..
as for the b/l theory b/l does change because of impedance but its realy not an increase in output because motor strength is also directly related to current(amperage) IE a higher flux field.. the absolute best option is to buy a huge class D and run it at 4 ohm... you get the highest efficiency, best dampening and best slew rate...
i recommend the mmats amps because there very powerful and very clean.. even ran @ 1ohm ive seen 72 to 74% efficiency with a DF of 200+ and a slew rate of over 10v/s.. most class D amps barely meet those numbers @ 4ohm...
it really bowls down to which amp is designed to give you the best efficiency output and budget for your electrical system..
Thinking about going with a massive audio p3000.1, 3000 watts rms at 2 ohm 6000 max cea certified. Any input on that amp? and i checked out most of the amps you guys posted there are a lot of good amps out there these days its hard to deside wth i want/
I myself would also like to know about this massive amp before I buy one.
Ouch, you are right! So I won't burn anything? This is great news!
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
196
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
852
loudstratus
loudstratus
Ohio/Western NY
RAM_Designs
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
