Subwoofer wiring to amp 2xDVC.4 Ohm to 1 Ohm
5t4y_50L0
CarAudio.com Recruit
I'm looking to wire each sub individually to my amp but 4 ohm down to 1 ohm
My amp is a ct sounds at and has 4 screw terminals
Am I right by wiring one 4 ohm sub down to 1 ohm and connect it to on set of terminals at the amp and same on the adjacent sub ?
Screenshot 2025-03-01 at 14-10-13 Subwoofer Wiring Diagrams for Two 4 Ohm Dual Voice Coil Spea...png
Ok, thank you, I wired one 4 ohm sub, positive to positive and negative to negative to a finale 2 ohm load. I then repeated the steps on 2nd sub, unfortunately I realized one screw on the amps 4 terminal speaker wire vibrated out and is lost. So just put the wires (4) into one side shared set.
That should be fine.
5t4y_50L0
5t4y_50L0
Oklahoma
Jimi77
