Gain Setting Tutorial
i was looking at the JL tutorial and i noticed how it said turn off all processing on my headunit but the treble and bass and loudness ect. dont affect my subwoofer only my mids and highs which arent amped....should i still have to worry about it or just set my volume at the loudest i listen to and turn off the bass boost and lower all the SUBWOOFER settings on my headunit (if it helps i have a Premier DEH-670MP)
IMO you should set it with everything set how you have it daily.
If you have the bass at +4 and the trebble at +6 with a EQ set the gain with everything that way. If you go and start changing things you risk clipping.
I followed the guid at JL audio's site. When I stick the voltage meter in the speaker wire input, all i see on the meter is 0.00 with a negative sign to the left of the 0's. I can only asume that means its not getting a reading. I know the meter works. What am I doing wrong?
This is probably a stupid question.
When you turn the volume down on your HU, should your sub be in sync with the volume?
My bud can turn his HU down to 13 and the subwoofer still plays loud like it was turned up all the way, but after 13 the sub's volume goes down.
Could this be any help to correctly setting gain??
He probably has his gain set too sensitive, meaning it maxes out at 13 instead of where it should. That also means he's probably clipping the hell out of it at max volume.
if i have 70watt RMS 4ohm comp 6.5s and a 65 watt RMS amp would i have to worry about the gain so much? THis stuff is really confusing me. I dont have anything to measure the voltages and all that. Also there is another option knob to turn on my amp besides gain and bass boost has something to do with htz what would i set that too?
Hey guys. I'm going to be setting up a new HU this weekend and will be re-setting all gains in my system (also new speakers). I've got a bit of a dilemma, though -- my mids/highs amplifier is easy, it's 2x140rms into 4ohms bridged. sqrt(140*4) = 23.66v to each speaker. The sub amp is a bit trickier; it's an old Punch 60DSM which is notoriously underrated. I can't really go off of 30w rms @ 4ohm, because the thing pushes 200+w.
Any ideas on how to get this set up not clipping, without an oscilloscope?
I was thinking i could burn 2 test tone tracks -- one at 0DBFS, and another at perhaps -1 or -2 DBFS. Play tone @ full 0DBFS, measure voltage at output poles to speakers on amp. Play tone -2dfbs. Measure voltage. If voltage is the same for both tones, it got clipped. If voltage for tone 1 is greater than tone 2, no clipping. Is this the right idea? Sorry if i just showed i am completely clueless //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
SirClay
President
SirClay
Texas
Tek18
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
