Gain Setting Tutorial
Then I suspect the amp pooched.
how can that be though? its not like there is no signal cause when i hook them up and play the test tone... his **** neighbors come out pissed so i know the amps still working. there is a signal it just wont pick it up.
i know. there is no other explanation other than i must be ****in up somewhere. i mean only thing that can be wrong is that i THINK i am doing it right and aren't. oh well when i see him again im gonna give it another go, and then probably another. thanks anyways guys.
not sure what 3 phase or 1 phase plugs are jmac
aneonrider: yea when i get 120 volts from the wall i have the black (ground in the com plug like the manual says) and then the red plug in the V part.
i just did it again. this time i actually got a reading. altho i believe with the equation i am suppose to be getting about 70 volts out of the viper but when i had my gain maxed out i only reached up to 40 volts. wouldnt go any higher with a 50hz test tone. any idea?
you serious? so increase sub level to +15 and this will result in me having to turn my gain down right? cause right now its at a little under 3/4 looks like to me. and if i leave gain at what it is now and have the sub level at +15 the bass will be SOOO over exagerated it wont even be funny. btw can anyone confirm this? cause ive been runnin my hu at +0 for as long as ive had it.
If you turn it up to +15, yes you will have to gain down.
ok 2 quick questions
1) is it really gonna make that much of a difference if i have the gain higher with +0 instead of having the gain lower with +15, or is it just gonna give me less of a chance of clipping if that even?
2) and if its at +15 does this only effect the sub amp? or will it also effect the mids/high amp. like will it be 4v for all preouts or just the sub preout?
Same advantage as running a line driver, the lower than gain knob is, the better s/n ratio, and the easier time the amp has running itself.
The full range outputs are 4V, just the sub out is affected like this.
I have a Brutus Hifonics Amp 1500BX. They are going to power two Alpine Type R's at 2 Ohms. Any idea at what i should set the gain on? The HU is a Alpine 9823, output is i think 4 volts. I dont want to get the multimeter cause I am really low on cash, and this thing would be a one-time use thing for me anyway. I looked through the first page of this thread and got really confused so I just skipped ahead to post. Sry if this has been repeated already.
ok yea, thats what it would seem like. so i guess im gonna try it again later today and looks like i gotta do it on my setup too.
bolla: you can just use the turn gain up till you hear distortion and then turn it down method. thats not really whats it called but it is an acceptable method.
SirClay
President
SirClay
Texas
Tek18
