Gain Setting Tutorial
You will be running the amp at a 2 ohms load, therefore it would be sqrt(1000*2) since the BX1500D puts out around 1000W into 2 ohms. What kind of box are you using?
Also, FYI, I am using one dual 4 ohm Type R.
i got a question. im now runnin a single sx in a sealed box. my gain was set for 2 sx's. i do the math and my voltage for 1 sx at 4 ohms is about the same as it was for 2 sx's at 2 ohms. now i wanted some clarification. the reason i need such a high voltage for 1 sub compared to 2 is due to the impedance right? since there is more resistance at 4 ohms im gonna need more voltage to get to the same spot right? im pretty sure im right i just wanna make sure.
70.7 volts @ 4 ohms = 1250 watts ...70.7 volts @ 2 ohms = 2500 watts ...
77.4 volts @ 4 ohms = 1500 watts ...
77.4 volts @ 2 ohms = Clipping, Audible Distortion, Overcurrent, etc. (If not underrated) ...
so when i get my second sx back im gonna set my gain to 70.7 volts like i had before right?
Any recommendations on a multimeter. I have already been to autozone (analog only), Kragen (digital with a scary rotary knob that I have no idea what all the settings were for and Radio Shack where I got the 29 range digital one for $29.99 but I am unsure if I got the right one of if perhaps I could have gotten a better one for the money. Please help. Thanks.
Edit: Okay 2 pages down on a search I found that someone here has the same one as I do so I guess it will do the job.
Is there any kind of division across channels for bridging? Like sqrt(1 600 * 4) = 80v so 40v per channel or do you do 40v for the bridge 'cause it's bridged? Would it be easier to measure the entire bridge or each channel?
Just measure the bridge, since that is the way you will be running the amp. And for example, if you have an amp that puts out 400W into 4 ohms bridged..
V = sqrt(400*4) = 40, then you would measure the bridged channels and set the gain to get 40V across them.
SirClay
President
SirClay
Texas
Tek18
