Gain Setting Tutorial
I have a question about setting gains: I was playing a 50Hz test tone to set my monoblock's gain. I noticed my components were playing this frequency even though they are crossed over @ 80Hz with the head unit's high pass filter. I dont need to use the amp's xover too, do I?
Also,
My amp does 175x2 RMS, but my components are 160RMS each. Should I use 160 or 175 when I am measuring the output of one channel?
Thanks
Do you have all speakers running off the head unit, separate amps, or a combination ?
The front components are running off a 175x2 RMS amp. The rear subs are running off the mono block, 750x1 @ 2ohm. The only speakers that are run off the deck are the rears. They were completely faded out when I was setting the gain on the mono amp though.
According to the manufaturer, the speakers are 160RMS, They are the CDT EF-61CFi/25 (560 xover + 1" silk tweet). I will have to readjust to 160 though, that will probably make them sound a little cleaner at higher volumes. They arent as crisp, clear, loud as I was hoping they'd be.
anyone got the red dmm from home depot? i recently dropped my old one and it broke...so i went to HD to buy a new one and now my friend wants me to set his gain and i cant get the **** thing to read anything off his amps yet itll read other electrical devices. whats up with that?
If it works on other things, but not on the amp, either you are "probing" wrong, or the amp is pooched. Are you sure you are set at AC volts?
i can take a picture of it and post it so you can see all the settings on it if you want? is that cool?
edit: this is the one i have
SirClay
President
SirClay
Texas
Tek18
