FS/T: Pair of Eclipse 5 Channels
whitedragon551
Moderator
14,193
79
IL
I have 2 Eclipse 5 channel amps. One is an XA5000 the other is a semi old school EA3532. Both are in near mint condition.
What Im looking for is either a single 5 channel amp or a matching pair. For a matching pair Ill look at a 4 channel and either a 2 channel or mono. I need atleast 500@2 or 4 ohms bridged for the mono or 2 channel. I only need about 50x4@4 on the 4 channel. Head room isnt a bad thing so offer up. Id love to try out a Minilith and Kronos (I know a long shot).
As for pricing if you want to buy separately.
XA5000: $235 shipped
EA3532: $135 shipped
Together: $360 shipped ($10 off)
First Ill put the XA5000 specs up and then the EA3532.
XA5000
A very under rated amp. The XA2000 rated for 300@4 bridged benched at 380@4 bridged of unclipped power.
XA2000 Review Here
XA5000 Manual PDF Download Here
My XA5000 Gut Shots
RMS Power Output (Watts x Channels) 50 x 4
300 x 1
Peak Power Output (Watts x Channels) 75 x 4
Power at 2 Ohms (Watts x Channels) 75 x 4
Bridged Power (Watts x Channels) 150 x 2
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Best Frequency Response 20-20k Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 90 dB
Input Voltage 14.4v
Features
Amplifier Class D
Low-Pass Crossover Frequency 50-200 Hz
Low-Pass Slope (dB/octave) 18 dB
High-Pass Crossover Frequency 30-500 Hz
High-Pass Slope (dB/octave) 18 dB
Bass Boost 0-8 dB
Bass Boost Frequency 32-64 Hz
Fan Cooled No
Fuse Rating 25 x 3
Speaker Level Inputs No
Preamp Outputs No
LED Power Indicator Yes
Width (inches) 15-3/4
Height (inches) 2-3/8
Depth (inches) 10-1/4
EA3532
Again another very under rated amp. This amp was made circa 2003.
My EA3532 Gut Shots
And last but not least pictures for both amps:
XA5000 Photobucket Pictures
EA3532 Photobucket Pictures
A link to my feedback is in my profile.
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
8K
I still have some Old school stuff that I really enjoy to this day. I still swapp amps and other gear I have from time to time and run for a...
17
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
